Expression to label coded values with a name
360
05-12-2019 12:39 AM
TimEatwell
I am trying to write a label class expression that will allow me to label polygons with a name (text code) rather than the number code in the source field. I have tried two options using a select case and elseif function, but I can't get it to work. Any help would be much appreciated.
Function FindLabel ([Type])
If '1' Then
Findlabel = 'SR'
ElseIf '2' Then
Findlabel = 'HG'
End If
End Function
or alternatively:
Function FindLabel [Type]
Select Case
Case '1' output = 'SR'
Case '2' output = 'rg'
Case '3' output = 'sg'
Case Else output = [Type]
End Select
End Function
Tags (1)
