Accumulate values in a raster in Modelbuilder
660
05-10-2019 02:30 PM
KathyFreeman1
I’m using Modelbuilder with a defined For loop (1 to 1000, for example) and a submodel.  In each  iteration of the submodel, I create a distance raster that I want to add to an Accumulation raster (which I want to be initially 0).  After the 1000th iteration, I want to put the Accumulation raster into a geodatabase.  To be clear, I don’t want to create 1000 rasters and add them together. I’d like to do everything in memory until I get the final accumulated raster that I save. It’s basically
Accumulate = Accumulate + SelectDist
Is this possible?  I have tried the Raster Calculator and the Plus tool and I can’t seem to accumulate anything.  I get the value of the last iteration.
DuncanHornby
MVP Notable Contributor
I think you need to edit your question and show the models you have.
