Image Analyst: is there a way to adjust mouse wheel sensitivity for z-value?
2451
05-13-2019 03:39 AM
BarbaraSchneider2
In Image Analyst, the height (z-value) of the stereo cursor can be changed by rotating the mouse wheel. I use a standard mouse. When I rotate the wheel one notch, the height interval of the stereo cursor is as follows:
  • approximately 0.5 meters on some ADS images
  • approximately 1 meter on other ADS images
  • approximately 2 meters on Ultracam frame images
I haven't found out why the above intervals are different, and what influences these intervals.
Prashant_MukeshMangtani
Barbara,
You can accelerate or decelerate the amount by which moving the mouse wheel changes height by using the Shift or Capslock key respectively. In a future release we will be providing users with more fine grained control over this.
-Prashant
BarbaraSchneider2
Hello Prashant,
thank you for your reply. It is important that users will have more fine grained control over this. It should be possible to define the height interval of one notch of the mouse wheel to 0.1 meters on all images.
Barbara
Barbara,
We totally understand and are working hard on a solution. Thanks for your feedback. Please let us know if you have any more questions or feedback.
-Prashant
