Set Default Location > Portal Folder
567
05-10-2019 06:01 AM
RobertBorchert
Honored Contributor
When Publishing a Web Layer in ArcGIS Pro.  Under Location you specify the Server and Folder.  We have a relational data store and our regular server.  The Share defaults to the RDS as the Folder option and we need to switch it to the other server.
Is there a way to set it so that the RDS is not the go to location?
In the drop down the RDS is listed at (Hosting Server)
