How to Automate "Calculate Geometry" Degrees Minutes Seconds within ModelBuilder?
3410
05-08-2019 06:02 AM
JohnSmith40
Does anyone know how I can add the functionality of "Calculate Geometry" (Units: Degrees Minutes Seconds (DDD MM' SS.sss" [W|E]) and Degrees Minutes Seconds (DDD MM' SS.sss" [N|S])) within ModelBuilder? I figured out how to automate the calculation of both decimal degrees and State Plane coordinates using the "Calculate Field" tool (see below):
Decimal Degrees (using Python 9.3):
arcpy.PointGeometry(!Shape!.firstPoint,!Shape!.spatialReference).projectAs(arcpy.SpatialReference(4326)).firstPoint.X
arcpy.PointGeometry(!Shape!.firstPoint,!Shape!.spatialReference).projectAs(arcpy.SpatialReference(4326)).firstPoint.Y
State Plane Coordinates (using Python 9.3):
!SHAPE!.firstPoint.X
!SHAPE!.firstPoint.Y
Thanks for your time.
DanPatterson_Retired
You could try a code block in the field calculator.
def dd_mm_ss(dd, cal_long=True, use_sign=True, use_quad=True):
    """decimal degrees to deg dec min"""
    deg_sign = u'\N{DEGREE SIGN}'
    deg = int(dd)
    if deg < 0:
        quad = ['S', 'W'][cal_long]
        deg = abs(deg)
    else:
        quad = ['N', 'E'][cal_long]
    if not use_quad:
        quad = ""
    if not use_sign:
        deg_sign = ""
    mins, secs = divmod(dd*3600, 60)
    degs, mins = divmod(mins, 60)
    frmt = "{}{} {:0.0f}' {:05.2f}{}''".format(deg, deg_sign, mins, secs, quad)
    return frmt
# expression box... python parser
dd_mm_ss(!YourField!, True, True, True)‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
yielding
# substituted a number for a field value to demo
dd_mm_ss(-75.5, True, True, True)
"75° 30' 00.00W''"
Of course, there are variants and you can mess with the code to suit your needs
    deg = int(dd)
    if deg < 0:
        deg = abs(deg)
    else:
    if not use_quad:
        quad = ""
    if not use_sign:
        deg_sign = ""
    return frmt
yielding
"75° 30' 00.00W''"
JohnSmith40
Thank you Dan. I tried running the above code and received the below error:
Start Time: Thu May 09 10:02:32 2019
ERROR 000539: Error running expression: dd_mm_ss(-110.7623741472387, True, True, True)
File "<expression>", line 1, in <module>
File "<string>", line 16, in dd_mm_ss
UnicodeEncodeError: 'ascii' codec can't encode character u'\xb0' in position 0: ordinal not in range(128)
Failed to execute (Calculate Field).
I'm using this code within ArcMap, not ArcPro - not sure if that has anything to do with Python 2 vs. Python 3.
big difference... python 2 doesn't support Unicode without some effort
try changing
to
deg_sign = "d" or just ""
and
frmt = "{}{} {:0.0f}m {:05.2f}{}s".format(deg, deg_sign, mins, secs, "")
print(frmt)
-75d 30m 30.00s
KyleBalke__GISP
An alternative solution would be the Add Geometry Attributes geoprocessing tool.
http://desktop.arcgis.com/en/arcmap/latest/tools/data-management-toolbox/add-geometry-attributes.htm
