Relevant if not equal to
6698
05-07-2019 12:37 PM
CarlHolt1
Currently have an equal in the Relevant field listed as
${FLOAT}='SEWAGE' or ${FLOAT}='SHEEN' or ${FLOAT}='SILTY' or ${FLOAT}='SUDS' or ${FLOAT}='OTHER'
Is there an equal similar to selected(${FLOAT}, !='NONE')?
Tags (1)
Jim-Moore
Hi Carl
The not() function might do the trick, as mentioned here: https://doc.arcgis.com/en/survey123/desktop/create-surveys/xlsformformulas.htm
For example: not(selected(${FLOAT}, 'NONE'))
If ${FLOAT} is a select_one question, you could also use: ${FLOAT} != 'NONE'
Please let me know if either of these are useful in your case.
Best regards,
Jim
Jim-Moore
Hi Carl
Best regards,
Jim
