Help with Inbox?
1228
05-07-2019 12:10 AM
AndrewMoskaLee
Our program does invasive plant control.  We have about 2500 sites in our database, that we try to visit each year to do control work.  We use Survey123 to document our control efforts.  Much of the data about each site, such as owner information and site descriptors, is the same each year.  Still crews must have the ability to edit all data points since owners do occasionally change.  Our survey is quite long and detailed and has a number of repeats to capture multiple site visits and herbicide applications within a season.  So we are trying to use the "inbox" and "sent box" features to manage bringing forward our old relevant data while being able to collect new information.  Then access sent sites using the "sent box" to add repeat site visits.  We have around 15 different crews that are each responsible for a portion of the sites.   For the most part crews are only responsible for their assigned sites, but sometimes crews trade sites and so they need to be able to fill out a survey for a site that is assigned to a different crew.
Currently I'm trying to figure out how to best manage the "inbox" feature.  If I don't use a "where clause", then crews can see and access all sites, but the inbox feature only holds 1000 sites, and loading the surveys is quite slow.  So then I tried adding a field to the connected feature service that contained the usernames of the crew members assigned to each site.  Then using the where clause, I can set the field 'assigned_crew_usernames' to equal ${username} of the person filling out the survey. But that solution doesn't allow crews to access any sites that were not originally assigned to them.
My next thought was to make 15 separate surveys that all point to the same feature service.  The surveys would be identical in every way except for the inbox where clause, which would be set to equal the 'assigned_crew' field.  That solution should work ok, but since this is our first year using Survey123, after many years of using SurveyCTO, I anticipate having to make changes to the Survey as the season progresses.  Having 15 separate surveys to have to make identical changes to each time seems especially onerous.
So does anyone have any suggestions as to how to best accomplish this work flow?  One thing I thought about was trying to use the "username" method and making a separate survey with just one or two questions that points to the same feature service. The main question on the supplemental survey would be; What are the assigned_crew_usernames?  Then crews could change the assigned_crew_usernames themselves, then return to the main survey and update the inbox.  Would that method work?  Would the inbox update with all of their assigned sites, each time they use refresh, including assigned sites that had already been completed earlier that season?
Any help would be greatly appreciated.
-Andy
FranciscoAndrade1
Andy,
I have a similar scenario like yours and we are using is a webmap app. We have someone login to the webmap app to assign jobs to our field personnel. The dispatcher has the option to use the batch attribute editor widget to mass assign jobs or use the edit widget to assign one job at a time.
Our dispatcher is assigning work to the field personnel throughout the day. Since Survey123 doesn't have any alerts once new jobs (surveys) have been assigned to a user, we use email or phone calls as a form of communication between the dispatcher and the field personnel.
Hope this helps.
DougBrowning
MVP Esteemed Contributor
We do this using a web map/collector to store the features then launch from there passing the ID to 123.  Then there is a backend relationship class that ties it all together.  This way 1 form is 1 record in the FC (so editor tracking, GPS of the visit vs assuming they were at the correct spot, etc all come along). Plus then they cannot change previous data.  I think the inbox method would be a mess and keep getting larger.
You can then have 1 map per crew.  As said above use an assigned to field.
by Anonymous User
Not applicable
Hi Andrew,
As I replied in your other post, https://community.esri.com/thread/233732-username-field-type-doesnt-work-with-inbox, if you are using 3.3, we have a known bug with Inbox filter and using where clause query with username field. This has already been fixed in the 3.4 beta builds available on EAC for download and via Testflight.
This was already reported in EAC forum here: https://earlyadopter.esri.com/project/forum/thread.html?cap=e69ef91f45744b98882c651f7b518eb7&forid={...
Please try out 3.4 beta and let us know if the Inbox where clause query you are trying to use is still not working?
Phil.
