Field Type Changes in a versioned Table with existing values
1288
05-06-2019 02:07 PM
jayshukla
Hi There, We have a geodatabase (ver 10.4.1) hosted on SQL Server 2012. There is a table that has field (Length) that requires field type change from long to double. This field has values. Since the field names are the same and only type changes, here is my workflow:
  • Create a field called LengthTemp
  • Using Edit session, Calculate value from Length to LengthTemp
  • Remove Length field
  • Add Length as double field type
  • Calculate value from LengthTemp to Length field
Here is the ESRI recommended approach.
  • First reconcile and post all the versions
  • Unregister feature class
  • Change schema
  • Register feature class as versioned
The issues that we have large number of editors and getting all the users to reconcile and post before making this change will result in delaying this update. I am curious how other community members are making these types of changes.
Appreciate any feedback.
Asrujit_SenGupta
i don't think "Unregister feature class" & "Register feature class as versioned" is required for this workflow. You can check the below technical Article for more details:
FAQ: What schema changes can be made to versioned data?
I would probably do the below:
- Disconnect all users and Reconcile\Post all versions
- Compress the geodatabase
- Make the schema changes
