Error creating RouteTask
1767
05-03-2019 04:18 AM
MassimoMazzanti
I'm writing a mobile Xamarin Android app that uses a network analysis service (NAS) to find routes.
This is my work environment:
Windows 10 Pro (v. 1809)
Visual Studio 2017 Community with Xamarin
ArcGIS Runtime SDK for .Net (v. 100.4.0; I also tried with v. 100.5.0)
Xamarin.Android... library packages (v. 27.0.2.1; I also tried with v. 28.0.0.1)
ArcGIS Server 10.5
The NAS uri is http://geoservizi.iuav.it:6080/arcgis/rest/services/network/venezia_network/NAServer/Route
To create a route task I use this code:
System.Uri myNasUri = new System.Uri("http://geoservizi.iuav.it:6080/arcgis/rest/services/network/venezia_network/NAServer/Route");
RouteTask solveRouteTask = await RouteTask.CreateAsync(myNasUri);
When I run the app I catch this error:
Error: Esri.ArcGISRuntime.ArcGISRuntimeException: Internal error: Data type Unknown
at Esri.ArcGISRuntime.Tasks.NetworkAnalysis.RouteTask+<CreateAsync>d__11.MoveNext () [0x0005f] in C:\daily_r\api_xam\dotnet\api\src\Esri.ArcGISRuntime\Esri.ArcGISRuntime.Shared\Tasks\NetworkAnalysis\RouteTask.cs:100
If I use another (more simple) NAS at http://geoservizi.iuav.it:6080/arcgis/rest/services/network/test3_service/NAServer/Route no error occurs.
Moreover, if I load in ArcMap the NAS that causes the error, and then I try to find a route with the Find Route tool, everything works properly.
Any idea what can cause the error?
Many thanks.
Massimo
JasonStearns
I'm having the exact same issue, only for WPF instead of android. My NAS works for 10.2.7 and in ARCMap
MichaelBranscomb
Esri Frequent Contributor
Massimo,
Please can you retest with 100.7?
Mike
MassimoMazzanti
Michael,
I solved the problem by following the tips in this thread
Transit Evaluator app error on ArcGIS Server
Now the app run correctly using 100.x SDK version.
Best regards
Massimo
