Auto complete a textbox from a map service in a widget
1775
05-02-2019 11:20 AM
TerryGustafson
I'm trying to auto populate a text box in a widget I have created.  I would like to be able to start typing a route and it returns the lists of routes as you type.  I don't need to know how to pass this object as I already have that working.  I found this post and tried to implement it in my application with not much success..  https://community.esri.com/people/mlewis22/blog/2014/10/21/autocomplete-search-box-using-arcgis-serv...
I was wondering if anyone else as has done this in a widget.js file?  Here is what my code currently looks like.  Any direction would be greatly appreciated.
_queryRoutes: function (Query, QueryTask) {
    //create array
    var array = []
    //build query task
    var queryTask = new QueryTask("https://app.mdt.mt.gov/arcgis/rest/services/LRS/LRM_RM/MapServer/0");
    //build query filter
    var query = new Query();
    query.returnGeometry = false;
    query.outFields = ["corridor"];
    query.where = "OBJECTID > 0";
    queryTask.execute(query, showResults);
    function showResults(results) {
        // Collect the results
        var resultItems = [];
        var resultCount = results.features.length;
        for (var i = 0; i < resultCount; i++) {
            var featureAttributes = results.features[i].attributes;
            for (var attr in featureAttributes) {
                 var routes = String(featureAttributes[attr]);
                resultItems.push(routes);
        // Sort the array
        var sorted = resultItems.sort()
        // Remove Duplicates
        var uniqueNames = [];
        $.each(sorted, function (i,el) {
            if ($.inArray(el, uniqueNames) === -1) {
                uniqueNames.push(el);
        array = uniqueNames
        var availableTags = array;
        $("#routes").autocomplete({
            // set the source as the availableTags above
            source: availableTags
I was able to create this html file but not sure how to incorporate it into my custom widget.
<!DOCTYPE html>
<html>
<head>
    <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no" />
    <link rel="stylesheet" href="https://js.arcgis.com/3.20/js/esri/css/esri.css">
    <link rel="stylesheet" href="https://code.jquery.com/ui/1.11.1/themes/smoothness/jquery-ui.css">
    <script src="https://code.jquery.com/jquery-1.10.2.js"></script>
    <script src="https://code.jquery.com/ui/1.11.1/jquery-ui.js"></script>
    <link rel="stylesheet" href="https://community.esri.com/resources/demos/style.css">
    <style>
        html, body,
        body {
            background-color: #FFF;
            overflow: hidden;
            font-family: "Trebuchet MS";
    </style>
    <script src="https://js.arcgis.com/3.20/"></script>
    <script>
      require(["esri/map", "esri/tasks/QueryTask","esri/tasks/query", "dojo/domReady!"], function (Map, QueryTask, Query) {
        $(function () {
            var array = []
            query.outFields = ["Corridor"];
                    var featureAttributes = results.features.attributes;
                        // Convert the attribute to a string. Null Values create an extra comma which stops the widget from functioning.
                        // push the attributes tothe blank array
                // Sort the array
                $.each(sorted, function (i, el) {
                    if ($.inArray(el, uniqueNames) === -1) uniqueNames.push(el);
                // Set the varrible array
                array = uniqueNames
                // This is your AutoComplete Widget
                // Reference the div id which you want the autocomplete list to appear (in this case tag)
                    // set the source as the availble tags above
    </script>
</head>
<body>
    <div class="ui-widget">
        <label for="routes">Corridor: </label>
        <input id="routes">
    </div>
</body>
</html>
I figured it out.   Needed to have the following libraries loaded in the index.html file.
<script src="https://code.jquery.com/jquery-3.4.1.min.js"></script>
<script src="http://code.jquery.com/ui/1.10.2/jquery-ui.js" ></script>
Tags (1)
