I am trying to configure email notifications for the Citizen Problem Reporter (local government ArcGIS Solution) per these instructions. I configured the Send Emails tool and tried running servicefunctions.py but get the following error from the log:
ERROR: Failed to process service https://services1.arcgis.com/stuff/arcgis/rest/services/stuff/FeatureServer/0
(504, b'5.7.4 Unrecognized authentication type [stuff.stuff.prod.outlook.com]')
I am not sure what is going on. I see this error pops up in other softwares when setting up SMTP. Some of the advice I've seen is to specify a port number, but I don't see where I can specify a port number. Does this have anything to do with the new TLS change? Let me know if further clarification is needed.
I have a similar problem. The app cannot connect to the SMTP server.
I have the email information like this in json configuration file:
"email settings": {
"smtp username": "username@gmail.com",
"smtp server": "smtp.gmail.com",
"smtp password": "password",
"reply to": "Username@bennettandwilliams.com",
"from address": "Username@Hotmail.com",
"use tls": true,
"substitutions": null
The Python gives a few trials and return a exception with this error message:
(421, b'Cannot connect to SMTP server 104.47.13.33 (104.47.13.33:25), connect error 10060')2019-07-02 11:07:59.829823
I also tried using hotmail (smtp.live.com), as well tried using the SMTP server name found on my PC (hotmail-com.olc.protection.outlook.com). It returns the same error message.
Any suggestions?
Ming
I ended up checking the TLS checkbox and it worked.
