Nested repeat -
2397
04-26-2019 11:55 AM
by Anonymous User
Not applicable
Hello All,
I'm trying to build an Survey request with a nested repeat schema. But I can figure how to resolve this problem.
From a series of responses added for the same type of elements (plants), a list of these elements should be made. For example, for the same site, I can have 20 different plants with their recovery percentage, which I want to consult and modify as needed. Once finished, I can create another site with the same characteristics.
I live an sketch in the attachments
Any idea and exemples?
How to connect my survey with ArcMap or WAB?
Thank you
Tags (1)
by Anonymous User
Not applicable
Hi Cristian,
Can you please share a copy of your xlsx file you are trying to create, and more information about the exact problem with nested repeats and which questions are not working as you expected?
Phil.
by Anonymous User
Not applicable
Hello, what I want to do is make a multiple choice in a nested field. Each of this choices will have to be visible as a list. In addition,
you should have access to edit for changes.
In section 5 (line 93-108), there is 3 repeat group that we are looking to have a list(each repeat groupe).In that way the user will be able to search
for a data entrance and change any information.
The xlsx it's attached
Any ideas?
JamesTedrick
Esri Esteemed Contributor
Hi Cristian,
To make sure I understand, are you trying to form a list based on choices that have been selected in previous questions?  If so, the Survey123 field app does not support this.
