Removing a Button
936
04-24-2019 05:06 AM
MickeyO_Neil
New Contributor III
My Add-In has several Features which can be activated and deactivated. If a Feature is deactivated a Button should be removed from a menu. But a custom condition only deactivats Buttons. How do I remove/change visibility of a Button at runtime?
SteveVan_Esch
For menus check out DynamicMenus, you add their constituent controls at run-time.
UmaHarano
Hi
Buttons cannot be hidden at runtime, but the group that holds the button can be hidden by using conditions and states.
Uma
MickeyO_Neil
New Contributor III
I only need to remove one button of a group/menu, the rest of the menu should remain.
But thank you for your tip.
SteveVan_Esch
MickeyO_Neil
New Contributor III
Thank you.
