Missing layers in service (and in app)
1273
04-23-2019 11:36 PM
JohnLocke1
Hi!
I have a problem that I cannot solve. Some days ago my layers disappeared from my map service. Only I see the group layers in the rest. See below:
Afternoon, it has worked, next morning, when I arrived to the job, the layers are gone. In ArcGIS Manager there were some logs at 00:36 for each layer:
"The Layer:'aabbcc' in Map:'map' is invalid. The base table definition string "%aabbcc" is invalid. Failure to access the DBMS server."
I cannot connect to the database in the ArcMap as well...
What can the problem be?? I restarted the SQL Server, the ArcGIS Server, the service, clear the rest cache, etc. No solution yet. Has anybody any opinion, how to solve this problem?
Thanks!
VictorTey
can you manually log into the database using the same credentials as your sde connection file?
