Unable To Connect To SQL Server
1253
04-23-2019 06:03 AM
KyleLawhorn
I'm trying to connect my Arc Catalog to the SQL Server I built.  It works fine until the server is turned off/restarted.  Then it is unable to connect again.
I get the following error message:
The thing that trips me out the most is when I do "New Database Connection" in Catalog, it shows my available databases but doesn't allow me to connect.
Server: Windows Server 2012 R2 w/ MS SQL 2012 SP3
Client: Windows 10, SQL Native Client & ODBC 13 Drivers.
Like I said, when I first installed SQL everything worked fine, but since restarting the server to apply an update everything fails.
ThomasColson
Are you running into this limitation
KyleLawhorn
I don't think so.  I'm currently using Arc 10.5.1
