Feature Hover widget?
7265
12
04-22-2019 07:12 AM
MarquesMunson1
I am new to WAB and I would like to know if there is a widget that allows a feature hover that allows the user to see a a feature highlighted when hovering over a feature with the mouse.
For example: A world map and when a user hovers over a country, the entire boundary is highlighted and/or outlined.
Any help is greatly appreciated!
RobertScheitlin__GISP
This may be of interest to you. It is a widget that will show the layers info window (popup) when you hover over the layer.
MarquesMunson1
I have found the Javascript code for the feature hover layer (https://developers.arcgis.com/javascript/3/jssamples/fl_hover.html). Can this somehow be added to WAB??
MarquesMunson1
Thank you for sending the zip file. I have downloaded and extracted to the widgets folder. Unfortunately for some reason WAB is not showing the new widget.
Marques,
Did you add the widget to the stemapp widgets folder (i.e. C:\web-appbuilder-2.11\client\stemapp\widgets\FLHover)?
Did you try closing WAB startup.bat command prompt window and restarting WAB?
Here is what it looks like:
MarquesMunson1
Yes, that is the steps I have followed. I downloaded the Identify widget and that works perfectly. I will remove the FL Hover widget folder, redownload the zip file and close WAB completely and restart.
MarquesMunson1
Hi Robert, It seems as though it DID work. I was looking for "FLHover" in the widgets tab but it is listed as "Feature Layer Hover." I just needed to look more closely!
HillaryBjorstrom
Hi, I was wondering if there was a way to set the config to have more than 1 feature layer. Thanks!
  "layerId": "FEATURELAYER_3931",
  "layerId": "FEATURELAYER_3932",
Currently no
HillaryBjorstrom
thanks for the quick reply.
