Host webappbuilder 2.11 application on webserver
942
04-21-2019 04:03 AM
KafilBaig
I am facing issue after hosting the application downloaded from webappbuilder 2.11
i created application from webappbuilder embeded with Portal for ArcGIS 10.6.1 and downloaded it and hosted it on webserver . The application loads fast there is no issues.
Whereas i created a application from webappbuilder 2.11 developer edition and downloaded the application and hosted on webserver . It’s keeps loading and application doesn’t open up.
Did anyone face this issue. Am I missing anything here. Please advice
RobertScheitlin__GISP
Kafil,
   What error are shown in the browsers web console?
RoberthSanchez
It sounds like you don't have anymore the map in portal used for your app in wab, can you please check the config.json and see if the param "itemId"(something like "1f20ce74437449f5b0d50913a8c53dd8") correspond to a map in Portal?
Regards.
