Spatial join point to point feature
1922
04-18-2019 04:37 PM
JonahLay1
I'm attempting to join a point feature class with another point feature class. Using the Spatial Join tool, I entered "closest" in Match Options and enter a search radius. Most of the attributes appeared, but there were a couple columns that returned "NULL." Is there a possible explanation for this?
Thanks in advance!
Tags (1)
CatherineClarke
I have just been trying to do the exact same thing on ArcGIS Pro (v 2.3.3) and got NULL for everything. I repeated the same process, using the same data, on ArcMap (v 10.5) and it worked fine. Therefore, I'm wondering if there is a bug with the Spatial Join geoprocessing tool on Pro when using 'Closest' as the match option.
Have you tried increasing your search radius? It may be the case you get NULL's for some when there is no feature within the search radius to join to...
