Voting application with appstudio
1100
04-15-2019 10:08 AM
DambéSANWOGOU
I wanted to know if it was possible to make a voting application with Appstudio, retrieve the data and display it on a dashboard...
GarethWalters2
Hi Dambé SANWOGOU‌,
Before going down the development path, have you seen the public surveys in Survey123? If you have and that doesn't fit your need,  I would suggest that you start with the Quick Report. This will allow you set up your questions/fields in the feature service and away you go.
Good luck,
Gareth
DambéSANWOGOU
Hi @gareth walter, I hope you found a solution, I also modified the code of my application by adding the url of my Survey123 form but nothing changes. The application opens with the Survey gallery
appstudio code
appstudio player
