Passing values from Survey123 to Collector
1520
04-12-2019 09:08 AM
ReneAubut
Hello, I have a Survey123 form from which i launch a Collector. In the label column of a Note field, I have this syntax to call the webmap used by Collector, then specify which feature to use, but am missing the part to pass on the value of a field in Survey123 to have it written in a specific field in Collector. I want the value of survey123 field UniqueID passed on to the Collector field UnicID. Thanks
<a href="arcgis-collector://?itemID=a5efd9a3b9864ee698b9893484452a45&featureSourceURL=https://services.arcgis.com/Cif2vyIafUMtRuVN/arcgis/rest/services/NouvLR_Collector_Saisie/FeatureServer/0&featureAttributes=???">Lancez App Collector pour la saisie de lignes ou polygones si requis</a>
by Anonymous User
Not applicable
Hi Rene,
Did you have a look at the Survey123 documentation here on integrating with other apps: https://doc.arcgis.com/en/survey123/reference/integratewithotherapps.htm#ESRI_SECTION1_BB1D69DBE8334...
Also check out this great blog about passing parameters via custom url scheme: https://community.esri.com/groups/survey123/blog/2016/07/30/understanding-survey123s-custom-url-sche...
Hope this helps.
Phil.
