ArcGIS Online/Arcade Populate Dates from another field?
1220
04-11-2019 03:06 PM
JordanHolt
Using ArcGISOnline and arcade I am wanting to populate a date field by adding 10 years to an Install Date field that is currently empty but will be filled out in the field using Collector for ArcGIS. The field I am trying to populate will be a WARRANTY_DATE field. The goal is for the user in the field to select and fill out the install date and it generates the warranty date then. Is this possible?
XanderBakker
Esri Esteemed Contributor
DanPatterson_Retired
Jordan, you should 'move' this to the ArcGIS Online‌ place to get some focused exposure.  You don't have to repost
XanderBakker
