SURVEY123 API ERROR
1135
04-11-2019 09:51 AM
JAVIERVARA_SANZ
Good morning.
I'm working on a python task that will use Survey123 API to generate a report, but keep obtaining the following error.
File "C:\Users\...\AGOLPRO\lib\site-packages\arcgis\apps\survey123\_survey.py", line 227, in generate_report
    "featureLayerUrl" : self._ssi.layers[0]._url.replace("_fieldworker", ""), AttributeError: 'NoneType' object has no attribute 'layers'
FYI, I'm pointing to a Survey that has specifically been designed to only review data (not editable).
Any advise will be highly appreciated.
Thanks.
Javier
by Anonymous User
Not applicable
Hi Javier,
Are you using the Feature Report API as documented in Survey123 EAC site: https://earlyadopter.esri.com/project/article/item.html?cap=e69ef91f45744b98882c651f7b518eb7&arttype...
If so this is a beta feature currently and you should raise any issues related to this in the EAC forum.
Phil.
