Problems with pulldata function in Survey 123
2831
04-09-2019 08:43 AM
AlexisGieseker
I am having trouble implementing the pulldata function using Survey123. I have a CSV file that contains site names and the address, city, district. That CSV has been put into the media folder of my survey. I believe my calculation formula is correct. When I go into my survey, the site name simply doesn't populate or return any value. Any help would be appreciated.
by Anonymous User
Not applicable
Copy the name column values from your sitename choice list over your pulldata file values and it returns Address, City, County values in the survey.  The values didn't match and there were a lot of special characters in that pulldata file.
AlexisGieseker
Can you attach the file back of what you did? I still can't get it to work on my end. Thank you for helping!
by Anonymous User
Not applicable
Just replace your pulldata file with this one and it works.
LDPWRI_ADMINMngomezulu
I am also experiencing the same issue with my pulldata() function in my survey for collecting movable assets for municipalities using barcode scanning.
