Generate Geodatabase
401
04-08-2019 11:51 AM
BrentSlone3
Generate geodatabase task only downloads the first feature class using this example:
https://github.com/Esri/arcgis-runtime-samples-qt/blob/master/ArcGISRuntimeSDKQt_QMLSamples/Features...
is this expected behavior?
Thank you,
Tags (1)
LucasDanzinger
Esri Frequent Contributor
I'm not seeing this behavior. Which version are you using? Are you in an area that only has the one layer visible in it? Here is my output which contains points, lines, and polygons:
BrentSlone3
Hey Lucas,
I am downloading the whole California and the Geodatabase only has points:
