Splitting polygon using ArcGIS Pro ModelBuilder?
1382
04-08-2019 11:37 AM
ChristinaPetsovits
Hello everybody,
I would like to split several polygon features using other polygon features inside a model. I use arcgis pro 2.2.4
When I do it manually, it works perfectly fine and quite fast, but inside the model builder it starts without producing an error but never finishes, even after hours of waiting.
What am I doing wrong? Or is there another tool that would produce the needed results?
There's a screen of my model attached.
The target feature is derived from Select (2), the cutting feature is derived from Select Layer By Attribute.
Thanks in advance for your answers.
Robert_LeClair
Esri Esteemed Contributor
General question rather than a solution.  I see you're using AGP 2.2.4 rather than the most current update AGP 2.3.2.  Not that I'm expecting the update of the software to fix this issue but there have been many bug fixes between the two releases.  I'd recommend, if you can, update to the latest version of AGP, try the workflow again.  Does the issue persist?
