Print Widget in WebAppBuilder
1975
04-08-2019 04:33 AM
mohannainar1
I have print widget (out-of-box) in my application. When I click print button its working for  BaseMap and operational layer (published as a mapservice) and its exported as PDF format.
The Issue is its not printing the custom featurelayer (dynamic feature layer). The layer created dynamically using the user uploaded CSV file.
Will the default print widget supports custom feature layer ?
Any alternate solution for this issue. #
TanuHoque
i should work. Print widget (which is powered by JS API Print task) knows how to work with csv file.
is it not working?
pls check the request that goes the print service.
mohannainar1
The issue resolved . I converted into GraphicLayer , now the print widget is working as expected . Thanks for your response on this
