Enable Button when Comboboxitem is selected
2099
04-02-2019 05:19 AM
UrsRichard
I have a Combobox and a Button. The button should be disabled until there is something selected in the Combobox. How can i achieve this with the ArcGIS Pro SDK?
Thanks for any help.
Urs
MatthewDriscoll
You need to create an event on the ComboBox.SelectionChange.  Inside that event handler use
button.Enabled = true;
UrsRichard
Maybe my topic wan't clear. The Button is a MapTool and the Combobox is is also in the ArcGIS pro Ribbon. So my question is how I can get a reference in the MapTool Object (Button) to Combobox Object and vice versa.
UmaHarano
You can implement States and Conditions to enable/disable controls on the ribbon.
ProGuide: Code Your Own States and Conditions
Sample: Working with DAML This sample has a section that creates a custom state and condition.
Uma
