Can not select a ArcGIS Online layer using OpenItemDialog
1008
03-27-2019 10:28 AM
FayuLai
I was trying to select a layer from ArcGIS Online using the following code.  I can click the layer but pDialog.Items also return empty.  Any ideas?
var pDialog = new ArcGIS.Desktop.Catalog.OpenItemDialog();
pDialog.MultiSelect = false;
pDialog.Filter = "tables_all";
pDialog.ShowDialog();
var pItems = pDialog.Items;
if (pItems == null) return;
var pList = pItems.ToList<ArcGIS.Desktop.Core.Item>();
if (pList.Count < 1) return;
var pItem = pList[0];
if (pItem == null) return;
FayuLai
I still cannot get this to work.  Any help will be greatly appreciated.
UmaHarano
Hi Fayu
I am not able to reproduce this - When I select a layer from the OpenItemDialog (available from MyContent on ArcGIS Online) pDialog.Items is not empty.
Can you please provide some information on the content you are trying to access? It is a standalone table?
Uma
FayuLai
Hi Uma,
Maybe it is to do with ArcGIS Pro version. It is not working in 2.2. But I tested in an ArcGIS 2.3 machine and it is working fine.
Thank you for your help!
Best regards,
Fayu
