Issue with ComboBox in custom widget
1528
03-27-2019 03:05 AM
OscarDiago_Alonso
Good morning.
I'm stuck trying to do simple widget with a CombBox.
My HTML look like this:
<div>
    <div data-dojo-attach-point="selectTipo"></div>
</div>
My Widget.js is currently just this:
define(['dojo/_base/declare', 'jimu/BaseWidget', 'dijit/form/Select', 'dojo/data/ObjectStore', 'dojo/store/Memory', 'dojo/domReady!'],
  function(declare, BaseWidget) {
    return declare([BaseWidget], {
      baseClass: 'jimu-widget-widgetprueba',
      startup: function() {
       this.inherited(arguments);
       var store = new Memory({
				data: [
				  { id: "foo", label: "Foo" },
				  { id: "bar", label: "Bar" }
		  var os = new ObjectStore({ objectStore: store });
		  var s = new Select({
			store: os
		  }, this.selectTipo);
		  s.startup();
But when I run this in the demo, I get this error.
ReferenceError: Memory is not defined
I have added the 'dojo/store/Memory', so I don't understand what the problem is!
Thanks for any help!
Tags (1)
KenBuja
MVP Esteemed Contributor
You have to include the arguments in your function that refer to the modules you're adding in the define
  function(declare, BaseWidget, Select, ObjectStore, Memory) {
KenBuja
OscarDiago_Alonso
Thanks! That worked!
RobertScheitlin__GISP
Also to add to what Ken has said if you are going to include widget in your template then you need to have the mixin added as well:
define(['dojo/_base/declare', 'jimu/BaseWidget', 'dijit/_WidgetsInTemplateMixin', 'dijit/form/Select', 'dojo/data/ObjectStore', 'dojo/store/Memory', 'dojo/domReady!'],
  function(declare, BaseWidget, _WidgetsInTemplateMixin, Select, ObjectStore, Mamory) {
    return declare([BaseWidget, _WidgetsInTemplateMixin], {
