Update shapefile's field using nearest shapelife
685
03-21-2019 07:57 AM
sotokan80_
I have a polyline shapefile (1.500.000 road segments) and  a point shapefile (the road segment's name). What is the most efficient way to update the polyline shapefile using info from the point shapefile.
Do i have to use a specific tool i.e SelectLayerByLocation_management and a cursor? Is there a more efficient way?
by Anonymous User
Not applicable
You could look into doing a spatial join which will join the two attribute tables based on their spatial location.
About joining the attributes of features by their location—Help | ArcGIS Desktop
Hope this helps!
DanPatterson_Retired
Near tool? Spatial Join? etc? depends on what you want the final results to look like
sotokan80_
The distance between point and polyline is calculated from polyline's middlepoint?
not with Near Near—Help | ArcGIS Desktop or spatial join Spatial Join—Help | ArcGIS Desktop
proximity is calculated for both of those using relationships described here
How proximity tools calculate distance—Help | ArcGIS Desktop
