QueuedTask in Visual Basic
1738
03-14-2019 08:23 AM
OscarDiago_Alonso
Hi!
I want to add a File Gedatabase to a project. Most of the documentation is only explained for C# and sometimes I have no idea how to tranlate it to Visual Basic.
I need to translate this code into Visual Basic:
string gdbPath = "@C:\\myDataFolder\\myData.gdb";
var newlyAddedGDB = await QueuedTask.Run(() => {
  //Create the File GDB project item
  var item = ItemFactory.Instance.Create(gdbPath) as IProjectItem;
  //If it is succesfully added to the project, return it otherwise null
  return Project.Current.AddItem(item) ? item as GDBProjectItem : null;
How can I create the QueuedTas in Visual Basic?
Tags (1)
UmaHarano
Hi Oscar
Try the Telerik Code converter.  I use that to convert code and it works well.
Uma
UmaHarano
Hi Oscar
Uma
OscarDiago_Alonso
Thanks! That page is going to help me a lot. This is my first time with vb.net and ArcGIS Pro SDK.
