Hi all,
I have upgrade our ArcGIS Enterprise solution from 10.6 to 10.6.1
However I have problem with Data Store configuration.
I ran configuration and it failed with Relational Data store.
I unregister it, and tried to run configuration wizard again.
But problem is that Relational Type is still "check", but at begening of wizard I have only TileCashe configured - so Relational should not be "check". So now I have unregister Relational DS and I could not configure new one.
Is there some config file where I can just simply delete that option ? Or some other trick?
Please see picture in attachment where you cen see the difference.
Thanks in advance
Martin
