Adding links to Map Popup(infoWindow)
1105
03-11-2019 07:37 AM
FranklinAlexander
I want to add a couple of links the the bottom of a popup for a result feature. I was able to do this for the popup that shows when clicking on one of the results in the Query widget results table. This is unfortunately a lot harder to do for the popup that shows when the feature is clicked on the map (the results are a point layer). I cannot find where in the application that the actual 'onClick' event occurs. The links must be added AFTER the point on the map is clicked, so adding them to the template is not as option. This is because the links are dependent on the field value for the clicked feature.
For the Query widget popup, I added two functions in the utils.js file:
addViewLinkToInfoWindow: function() {
            var attSect = query('.attachmentsSection', this.domNode)[0];
            var attList = query('.attachmentsSection ul', this.domNode)[0];
            var titleDiv = query('.attachmentsSection div', this.domNode)[0];
            html.removeClass(attSect, 'hidden');
            titleDiv.parentNode.removeChild(titleDiv);
            var viewurl = "https://fwc-spdev5.fwc.state.fl.us/FRRP/Sites/Details/3020";
            var viewTransect = domConstruct.toDom('<li class="viewSite"><strong><a href="' + viewurl + '" target="_blank">View Site Details</a></strong></li>');
            domConstruct.place(viewTransect, attList);
            //console.log("attribute list ", attList);
addTransectLinksToInfoWindow: function() {
            var addurl = "https://fwc-spdev5.fwc.state.fl.us/FRRP/Transects/Add/3020";
            var addTransect = domConstruct.toDom('<li class="addTransect"><strong><a href="' + addurl + '" target="_blank">Add or Edit Transect</a></strong></li>');
            var editTransect = domConstruct.toDom('<li class="viewSite"><strong><a href="' + viewurl + '" target="_blank">View Site Details</a></strong></li>');
            domConstruct.place(addTransect, attList);
            domConstruct.place(editTransect, attList);
And then I called them in the SingleQueryResult.js file in the _onResultsTableClicked (event)
if(transectNum === 2) {
     queryUtils.addViewLinkToInfoWindow();
     this.map.infoWindow.show(centerPoint);
} else {
      queryUtils.addTransectLinksToInfoWindow();
If anyone knows where I can add this code so that I can add the same links to the popup resulting from a feature click, can you please let me know. Popups(infoWindows) can be confusing! lol
Thank you!
RobertScheitlin__GISP
FranklinAlexander
Thanks Robert,
That will get me going in the right direction. And If I am reading correctly I should be able to use the Feature Action for both the Query popup and the map popup!
Correct
