How to sort dynamic text from table attribute?
3411
03-04-2019 01:42 AM
MattiasEkström
I'm adding street names to a layout by using dynamic text from table attributes. It kind of works, but I want the streets names to be sorted ascending by name. Is that possible? I tried to use a custom SQL expression where I added ORDER BY, the expression is valid but when applying that expression my text disappear. Removing the ORDER BY part brings my text back but obviously not sorted the way I want.
A work around could be to permanently reorder all the features in the table by some script, but that's not the solution I'm looking for.
TomBole
Hi Mattias,
ORDER BY is not supported by Dynamic Table Attributes.
I'm curious on why you are not using Table Frames - Add and modify table frames—Layouts | ArcGIS Desktop - to display a sorted list of street names.
Tom
TomBole
Hi Mattias,
Tom
MattiasEkström
Hi Tom,
I'm still new to ArcGIS pro, so the reason that I don't use Table Frames is that I missed it, that's definitely what I'm supposed to use in this case. Thanks!
TomBole
Hi Mattias,
That's good news.  Please let us know if you have any questions or issues with using Table Frames or anything else.
Tom
CRose
I have the same question, but table frames don't seem to work for me. I have dynamic text in which I am concatenating several of the feature's attributes into a paragraph. I would like those to appear in order based on a certain column.
My work-around right now is to export the table to csv, order however I want using Excel, delete all rows in the table in Arc, then re-import the csv rows, which gives every row a new ObjectID.
I would really prefer to have an "order by" option within the Insert Table Attribute dialog.
