Reconnect Layers to Source
2329
9
03-01-2019 12:53 PM
MichelleCouden
Is there a tool that will reconnect your layers to the source all at once.
Tags (1)
MichaelVolz
Esteemed Contributor
Definitely looking forward to getting this functionality from ArcMap.
Robert_LeClair
Esri Esteemed Contributor
If all your broken data links point to the same geodatabase or same folder of shapefiles, yes.  Click on the Red Exclamation point for the layer in the Contents Pane and AGP will reconnect all the layers.
MichaelVolz
I'm looking for equivalency of the Set Datasource Tool in ArcCatalog portion of ArcMap.  You could reset any number of different sources at once.
Robert_LeClair
I understand what you're asking - to my knowledge there is not an equivalency from ArcMap to AGP for this.  I see you responded to the ArcGIS Idea thread.
MichaelVolz
This is quite disappointing as that is a really useful tool.
Robert_LeClair
Agreed - I'd recommend adding it as a new ArcGIS Idea and/or supporting (if there is) an existing idea to have this function in ArcGIS Pro 2.x.
ThomasColson1
This is another one of those frustrating lack of equivalency issues that baffles me. Why is an idea or an enhancement request needed?
KoryKramer
Esri Community Moderator
I'll check to see where we are on this onehttps://community.esri.com/ideas/12449
Robert_LeClair
There appears to be an enhancement request ENH-000117737 for this functionality and is listed as in the Product Plan.
