Add loading icon to url button custom widget
5191
10
03-03-2019 01:27 PM
CarolineBettach
 Do you know how can i change your url button code custom widget and add a loading icon that will be s display when clicking on the button on will be hidden when the service will return a response?
RobertScheitlin__GISP
Caroline,
   You just have to hitch your result and error function to the current scope of this.
requestHandle.then(
  lang.hitch(this, function (response) {
    var responseJSON = JSON.stringify(response, null, 2);
    //alert(responseJSON);
    this.loadingPanel.hide();
    this.isOpening = false;
    WidgetManager.getInstance().closeWidget(this);
  lang.hitch(this, function (error) {
    //alert( error.message);
Caroline,
  Here is how to do it if you have the widget in one of the onscreen widget icon placeholders:
// Copyright © 2016 Robert Scheitlin. All Rights Reserved.
define([
    'dojo/_base/declare',
    'dojo/_base/lang',
    'jimu/BaseWidget',
    'jimu/WidgetManager',
    'dojo/query',
    'dojo/_base/html',
    'dijit/registry'
  function(
    declare,
    lang,
    BaseWidget,
    WidgetManager,
    query,
    html,
    registry) {
    var clazz = declare([BaseWidget], {
      baseClass: 'widget-urlbutton',
      isOpening: false,
      pWidget: null,
      onOpen: function(){
        if(!this.isOpening){
          this.isOpening = true;
          var urlBtnArr = query("div[data-widget-name='UrlButton']");
          urlBtnArr.some(lang.hitch(this, function(node){
            var parentWid = html.getAttr(node, 'widgetId');
            if(html.hasClass(node, "jimu-widget-onscreen-icon")){
              this.pWidget = registry.byId(parentWid);
              if(this.pWidget.widgetConfig.id === this.id){
                setTimeout(lang.hitch(this, function(){
                  this.pWidget._showLoading();
                }), 200);
                return true;
          //now run your web service stuff and wehn that finishes
          //then do the next three lines
          this.pWidget._hideLoading();
    return clazz;
CarolineBettach
Thank you for your answer.
I have added your code but it does not work cause i get html.hasClass(node, "jimu-widget-onscreen-icon"is false
I think i need to add something but i don't know how .this framework is new for me,please let me know what i need to add and how.
Thank you so much
Caroline,
  If that is the case then you do not have the widget in a on screen widget placeholder like I mentioned the code was written for. What theme are you using and where in that theme do you have your widget placed?
CarolineBettach
this is my  app config.json ,
What do i need to change?
Caroline,
   You have the widget inside the HeaderController widget. The code I provided is not made for the widget to be placed there. If you move it to one of the on screen placeholders then it will work as intended.
CarolineBettach
Thank you it works now.
But  it is not what i wanted.
What i want is when the user click on the url button it will display a loading icon overlay in the middle of the page and that the user won't be able to touch any button in the app until i hide the loading icon panel.
Sorry for the misunderstanding.
Could you please tell me what changes do i need to make in the urlbutton code?
Thank you
CarolineBettach
I would like to add this Show loading icon | ArcGIS API for JavaScript 3.27  when i click on a url button but how to change my url button code?
Here is that. Be sure to add your busy image to the widgets images folder and update the url in the code.
define([
    'dojo/_base/lang',
    'jimu/BaseWidget',
    'jimu/utils',
    'esri/dijit/util/busyIndicator'
  function(
    declare,
    lang,
    BaseWidget,
    WidgetManager,
    utils,
    busyIndicator) {
      isOpening: false,
      pWidget: null,
      onOpen: function(){
          var busyURL = utils.processUrlInWidgetConfig("images/predefined_loading_4.gif", this.folderUrl);
          this.handle = busyIndicator.create({
            target: "map",
            imageUrl: busyURL,
            backgroundOpacity: 0.5
          this.handle.show();
          //Then when your service is done
          this.handle.hide();
    return clazz;
CarolineBettach
 Thank you so much for your help!!
Now it's ok i see the loading icon but after i get the response from the rest service i try to hide the loading icon with:
this.loadingPanel.hide();   but it does not hide because when i debug i get this.loadingPanel is undefined.
Please help me to resolve this problem
thank you
define([
'dojo/_base/lang',
'jimu/BaseWidget',
'esri/request',
'jimu/utils',
function (
declare,
lang,
BaseWidget,
WidgetManager,
esriRequest,
utils,
busyIndicator
isOpening: false,
loadingPanel: null,
onOpen: function () {
if (!this.isOpening) {
var busyURL = utils.processUrlInWidgetConfig("images/Spinner.gif", this.folderUrl);
this.loadingPanel = busyIndicator.create({
target: "map",
imageUrl: busyURL,
this.loadingPanel.show();
var layerUrl = "http://tapat4/restservice/api/calc";
var requestHandle = esriRequest({
url: layerUrl,
content: { f: "json" },
handleAs: "json"
requestHandle.then(
function (error) {
} //if this opening open
} //on open
}); //clazz declare
return clazz;
}); //function
