Sequence Size error in Update Cursor
1587
02-27-2019 03:12 PM
JoeBorgione
I have this reoccurring nightmare... (see 'ascii' codec can't encode character u'\u201c'  )  I keep coming back to this script where I need to replace a new line ('\n') in a field.  I have somehow gotten past the error in the referenced thread, but now I'm faced with
TypeError: sequence size must match size of the row
import arcpy
arcpy.env.workspace = r'J:\WaterQuality\test_tables.gdb'
table = 'FieldParameters'
fieldNames = [f.name for f in arcpy.ListFields(table,'','String')]
for fieldName in fieldNames:
   field = [fieldName]
    with arcpy.da.UpdateCursor(table,field) as cursor:
      for row in cursor:
        if row[0] == None:
          pass
        elif '\n' in row[0]:
          print(row[0])
          row[0] = row[0].replace('\n','=>')
          print(row[0])
          cursor.updateRow(row[0])
Water has a green/grey tint
Water has a green/grey tint=>=>
Line 18 through line 20 are returned from the print statement on line 13.  The actual value of the field is:
Water has a gren/grey tint\n\n
Line 21 is returned from the print statement on line 15: I have successfully replaced both \n characters with =>
However, it errors with:
Runtime error
File "<string>", line 23, in <module>  (line 23 is shown as line 16 above)
This table has 11 string fields, the first 9 do not have any \n characters in any of them.  I hit the 10th field and the first record it finds with a \n tosses the error.
This is being run in the Arcpy window of ArcMap 10.6.1. I've tossed this error before with an insert cursor (see: Brain cramp with an Insert Cursor from 9 months ago) and I was able to resolve it then.  I just don't see what I'm doing wrong this time.
My goal is to loop through a list of tables and their respective string fields looking for \n characters and replace them accordingly.  In a  search cursor and find all the offenders just fine, but fixing them is another story.
DanPatterson_Retired
don't you want to update the row?
 row[1] = row[0] * 100
 cursor.updateRow(row)
Accessing data using cursors—ArcPy Get Started | ArcGIS Desktop
that may be why your sequence size is incorrect
Don't know about the loopy stuff, but just want to make sure that you are looking for the right thing
EDIT
Added a 'check_for'
def stuff_test(i, check_for=r"\n"):
    if i is None:
        print("None type")
        return str(i)
    if check_for in i:
         print(f'is in, {i}')
    else:
         print(f'not in {i}')
    return i
# ---- stuff to check
stuff = ['n', '\\n', 'a\n', None, r'b\n', r'c\n']
# ---- not raw encoded
back = [stuff_test(i, "\n") for i in stuff]
not in n
not in \n
is in, a
None type
not in b\n
not in c\n
# ---- raw encoded
back = [stuff_test(i, r"\n") for i in stuff]
not in n
is in, \n
not in a
None type
is in, b\n
is in, c\n
JoeBorgione
Just what I needed: another pair of eyes!  Thanks Dan.  No more nightmares. Until the next one...
