lang.hitch scope is null error while building widgets
5317
13
02-27-2019 09:48 AM
Rohit_Venkat_GandhiMendadhala3
I am trying to build a widget which will retrieve the place links if we type an address or drop a pin at a location. It will provide links to Google 3D, Birdseye view. But when I start the server and import the widget in my application it shows up this error that widget cannot be created.  When I look into the console, it shows that lang. hitch scope is null. Here is the screenshot for your reference.
RobertScheitlin__GISP
Rohit,
Look at the create widget error right above the lang.hitch issue. Line 117 of your Placelinks widget is where you need to focus your debugging efforts.
Thank you very much Robert.
I checked the widgetmanger.js inside jimu.js folder
I think the line 117 is console.log('create [' + setting.uri + '] error:' + err.stack);
Is create[setting.uri] causing the issue?
Rohit,
  Do you have a settings.js for this widget?
Yes I do have it
Rohit,
  Try removing the whole settings folder from your widget and if your manifest.json has about hasSettingPage or hasSettingsUI set them to false and see if the issue goes away.
Didn't work for me Robert. Can send you a zipped file if needed. Thank you
Rohit,
  At this point I do not know what else to tell you without seeing your code.
Rohit_Venkat_GandhiMendadhala2
Thanks Robert,
Can you share your email so that I can send the widget in a zipped file?
Appreciate your help. Thank you
Rohit,
  Sorry I only provide help online here and do not exchange emails. You can attach your widget to a reply when using the advanced editor.
