NumPyArrayToFeatureClass gives RuntimeError: create table
4451
8
02-26-2019 01:26 AM
GrzegorzJeleniewicz
I've tried to change polygon feautre  to point by using tools:
FeatureClassToNumPyArray
NumPyArrayToFeatureClass.
My code as below:
import arcpy
import numpy as np
in_file='C:/ios/OneDrive/siatki_obliczeniowe/siatki.gdb/siatka_005'
a = arcpy.da.FeatureClassToNumPyArray(in_file, ["*"], explode_to_points=False)
out_file='C:/ios/OneDrive/siatki_obliczeniowe/siatki.gdb/xxxx3'
arcpy.da.NumPyArrayToFeatureClass(a, out_file,["shape"])
I got an error:
  File "C:/ios/OneDrive/python/feature_to_point.py", line 7, in <module>
I had changed out_file to shp file and it works but it is not solution for me. I would like to be able write to .gdb.
Any idea how to solve this problem?
DanPatterson_Retired
your geometry field... what was it named? and what was it in the array?
you indicate it was ['shape']? or ['Shape@'] or 'SHAPE@' or some other variant
use
a.dtype‍
and get the exact case and spelling of the geometry field.
Also you will need to set
...explode_to_points=True)  # in order to get points, ‍
you can't set explode_to_points=False, unless you want the centroid of the original polygon
Thirdly, if the output featureclass name exists, it will fail
GrzegorzJeleniewicz
Thank you for your answer.
my geomtery field is ['Shape']. I've cheked it with a.dtype and got result:
[('OBJECTID', '<i4'), ('Shape', '<f8', (2,)), ('Shape_Length', '<f8'), ('Shape_Area', '<f8'), ('miasto', '<U50')]
I've changed small 's' for capital 'S', but it didn't help
Yes, I want the centroid of the original polygon, so explode_to_points=False is ok for me.
The output featureclass name is set to new each run.
hmmm if you only want the centroid coordinate, you should avoid using the true shape, but use one of the alternates and specify your field names explictly
FeatureClassToNumPyArray—Data Access module | ArcGIS Desktop
you can easily parse the fields rather than using "*" which is ok in some situations, but the shape field should be parsed into x and y coordinates usually
flds = ['OID@', 'SHAPE@X', 'SHAPE@Y']
other_flds = [i.name for i in arcpy.ListFields(fc) if i.type not in ('OID', 'Geometry')]
flds.extend(other_flds)
flds
['OID@', 'SHAPE@X', 'SHAPE@Y', 'ID', 'Norm', 'Rank1', 'Text01', 'Text02', 'Xs', 'Ys',
 'Int_short', 'Float_fld', 'Grid_code', 'Rank_shp', 'PolyID', 'Grid_Count',
 'Diff_from_mean', 'x']
GrzegorzJeleniewicz
I changed my code following your instructions:
import arcpy
import numpy as np
in_file='C:/ios/OneDrive/siatki_obliczeniowe/siatki.gdb/strefy_miejskie_siatka_01'
other_flds = [i.name for i in arcpy.ListFields(in_file) if i.type not in ('OID', 'Geometry')]
a = arcpy.da.FeatureClassToNumPyArray(in_file, flds, explode_to_points=False)
out_file='C:/ios/OneDrive/siatki_obliczeniowe/siatki.gdb/axxxyz9'
print (a.dtype)
arcpy.da.NumPyArrayToFeatureClass(a, out_file,['SHAPE@X', 'SHAPE@Y'])
Unfortunately I got error again:
  File "C:/ios/OneDrive/python/feature_to_point.py", line 10, in <module>
The most annoying  fact is that if I change the 'out_file ' to shp file instead of feature class in geodatabase (.gdb) it works (with both code versions). For sure there is a problem with saving output to geodatabase (.gdb). I have no clue why.
Just noticed you are using python 2.7... may be the issue since I have no problem using the process with either points exploded or not exploded using python 3
GrzegorzJeleniewicz
I've got already the solution and posted link to it above.
for future reference
all_flds = [f.name for f in arcpy.ListFields(fc, "*")]
editable_flds = [f.name for f in arcpy.ListFields(fc, "*") if f.editable]
all_flds
['OBJECTID', 'Shape', 'Grid_codes', 'F_', 'Shape_Length', 'Shape_Area', 'Rand_0',
 'Rand_1', 'Shape_Length_1', 'Shape_Area_1']
editable_flds
['Shape', 'Grid_codes', 'F_', 'Rand_0', 'Rand_1']
OBJECTID, and Shape info can be accessed through their @ property, other variants of Shape aren't editable and removing them from the list of candidates is a safe bet... at least for a file gdb
