Time slider widget text
1782
5
02-21-2019 06:33 AM
Nicole_Ueberschär
I am using the time slider widget within a Launchpad themed AGOL web application.
I am wondering if nobody else is annoyed about the fact that the style of the text does not match at all the other text within the application.
This looks so stupid! Is there a way to fix this somewhere in the json maybe or do I need to submit a case for this?
Tags (1)
RobertScheitlin__GISP
There is nothing that can be done in the json for this. It is a css issue.
Nicole_Ueberschär
Is it only me who doesn't like that kind of styling?
Nicole,
  Yes it does not look good for one element of an app to use a different font. This was most likely an oversight.
Nicole_Ueberschär
Would I need to open a support case for that or who can I ask to change it?
A support case is always the best way. You could also add an enhancement idea to the ideas page but I tend to see better results with tech support.
