Point In Polygon Search
860
02-20-2019 03:40 PM
MauricioRamirez1
We have a system that brings in the Lat/Lon of field units.  They are made available to my application by our message bus.  I'm wanting to find out if an incoming unit is within any of our "Areas Of Interest".  My thought was to load the "Area Of Interest" layer from teh GIS server into memory and as the unit locations come in, check them all in memory.  The application would not have a display, and would run in the background and if a unit falls inside of the area of interest, it would send a message via our message bus. Questions:
  1. Can I have a Qt application utilizing the Qt Runtime with no display
  2. Can I pull a layer from the ArcGIS server on startup and load it into memory for query
Rasmus_BloustrødLind
Hey Mauricio
To load a featurelayer in a QT app in gml code  use:
            FeatureLayer{
                ServiceFeatureTable{
                    url: featureServiceURL
this has to be loaded inside a mapview though. But if you do not add a Map {} part to the code there will not be displayed a map
after this the featurelayer should be able to be call on the id
hope this can help
best
rasmus bloustrød lind
MauricioRamirez1
Rasmus,
Thanks for the quick reply.  I will definitely give that a try.
