ArcGIS Pro PDF export not maintaining georeferencing information
1516
02-19-2019 09:23 AM
DalindaDamm
Has anyone noticed a PDF exported from ArcGIS Pro (v2.2.2), which has the 'Export map georeferenced information' option enabled, not holding the georeferencing information when being pulled into a PDF viewer like Avenza? My client has tried this workflow when exporting using both a map view and a layout view, and neither situation works.
SarahBalabanov
Find a solution? We've just run into this problem on Pro 2.2.3. Waiting on a server update from IT so we can go to 2.4 and see if that fixes it.
KyleOberg
Update to 2.4 fixed for me.
DalindaDamm
Thanks for the update Kyle. I'll have to try that out.
ChrisRay
I'm on 2.4.1 and just discovered I'm having this problem. Turns out I had the "output as image" checkbox checked in the export dialogue. Not sure if that's the default but you want it unchecked to maintain the spatial information.
