Xlsxwriter package won't install after updating pro to version 2.3
1462
02-15-2019 01:16 PM
ChelseaTabor1
I updated ArcGIS Pro to version 2.3.0 this morning and updated my installed packages in the Python Package Manager.  However, after the update I'm missing the xlsxwriter package that I already had installed before the update.  I can find it when I search for packages, but the install won't work for me.  I've tried a few times now to reinstall the xlsxwriter package with no luck.  Does anyone know why it wouldn't be working?
DanPatterson_Retired
in your cloned environment?
If you are in control of your computer, you will have to install it in your cloned environment.
If you are in control, then you can do usually do an install using conda (your proenv.bat file)
But a dry run shows it isn't in the default channels
(arcgispro-py3) C:\...Your_Install_folder\bin\Python\envs\arcgispro-py3>conda install xlswriter --dry-run
Fetching package metadata .............
PackageNotFoundError: Packages missing in current channels:
  - xlswriter
We have searched for the packages in the following channels:
  - https://repo.anaconda.com/pkgs/main/win-64
  - https://repo.anaconda.com/pkgs/main/noarch
  - https://repo.anaconda.com/pkgs/free/win-64
  - https://repo.anaconda.com/pkgs/free/noarch
  - https://repo.anaconda.com/pkgs/r/win-64
  - https://repo.anaconda.com/pkgs/r/noarch
  - https://repo.anaconda.com/pkgs/msys2/win-64
  - https://repo.anaconda.com/pkgs/msys2/noarch
  - https://conda.anaconda.org/esri/win-64
  - https://conda.anaconda.org/esri/noarch
I wouldn't suggest installing it as instructed from the anaconda pages, since it wants to update everything
(arcgispro-py3) C:\arc_pro\bin\Python\envs\arcgispro-py3>conda install -c anaconda xlsxwriter --dry-run
Fetching package metadata ...............
Solving package specifications: .
Package plan for installation in environment C:\arc_pro\bin\Python\envs\arcgispro-py3:
The following NEW packages will be INSTALLED:
    xlsxwriter:          1.1.2-py36_0           anaconda
The following packages will be UPDATED:
    openssl:             1.1.1a-he774522_0               --> 1.1.1-he774522_0       anaconda
    vs2015_runtime:      14.15.26706-h3a45250_0          --> 15.5.2-3               anaconda
The following packages will be SUPERSEDED by a higher-priority channel:
    asn1crypto:          0.24.0-py36_0                   --> 0.24.0-py36_0          anaconda
    atomicwrites:        1.3.0-py_0                      --> 1.3.0-py_0             anaconda
..... Huge Snip .....
pip install if you really need
or they do have
xlrd                      1.2.0                    py36_0
xlwt                      1.3.0            py36h1a4751e_0
which I find good and I have used it with my excel-array-table scripts
This can be used to convert excel files to numpy structured or record arrays. · GitHub
from this link
/blogs/dan_patterson/2018/12/13/excel-arrays-tables-in-arcgis-pro
Good luck
