Pro Computer Usage
1238
02-14-2019 12:01 PM
by Anonymous User
Not applicable
I have noticed that when Pro is running heavy lifts (i.e. raster operations with large rasters) according to my task manager Pro is only using about 15-20% of my CPU and RAM. Am I somehow set to only use one core? Is there a way to make Pro use more of my hardware, or is my computer just limited by the read/write speed to my HDD?
Thank You
LR
Some operations cannot be processed in parallel because they are linear (e. g. calculating something that requires the result of previous calculations). Others, like updating table values, can be split because they're independent of each other.
Some tools have a "parallel processing factor" under the Environment tab. Inputting "100%" will create a process for each of your CPU cores. If you want to specify how many processes you want to spawn regardless of your cores, use a number.
LR
