dictionary{} processing
650
02-13-2019 10:15 AM
JamesCrandall
Looking for most efficient method to update a dictionary that I'm populating from a REST map service and then attempting to alter as needed.  The desired alteration is simple: duplicate each item and swap value in two of the attributes of the newly copied item.  Best way to describe is just show current vs. desired output below!
(attributes "juncA" and "juncB" must have their values swapped on copied item).
Current:
  "junctionMatrix": [
      "attributes": {
        "WCU": "C1",
        "calcMethod": "AERIAL",
        "juncA": "S47D",
        "juncB": "CR-03.0",
        "juncDistance": 8501.86072183
      "attributes": {
        "WCU": "C1",
        "juncA": "S47B_C",
        "juncB": "S47D_S",
        "juncDistance": 17535.28122721
Desired:
  "junctionMatrix": [
      "attributes": {
        "WCU": "C1",
        "juncA": "S47D",
        "juncB": "CR-03.0",
      "attributes": {
      "WCU": "C1",
      "juncA": "CR-03.0",
      "juncB": "S47D",
      "attributes": {
        "WCU": "C1",
        "juncA": "S47B_C",
        "juncB": "S47D_S",
      "attributes": {
        "WCU": "C1",
        "juncA": "S47D_S",
        "juncB": "S47B_C",
DarrenWiens2
I'll leave it to you whether this is "most efficient", but it works:
import copy
new_list = []
for i in mydict['junctionMatrix']:
    i_copy = copy.deepcopy(i)
    i_copy['attributes']['juncA'] = i['attributes']['juncB']
    i_copy['attributes']['juncB'] = i['attributes']['juncA']
    new_list.append(i_copy)
mydict['junctionMatrix'] += new_list
mydict
{'junctionMatrix': [{'attributes': {'WCU': 'C1',
    'calcMethod': 'AERIAL',
    'juncA': 'S47D',
    'juncB': 'CR-03.0',
    'juncDistance': 8501.86072183}},
    'juncA': 'S47B_C',
    'juncB': 'S47D_S',
    'juncDistance': 17535.28122721}},
    'juncA': 'CR-03.0',
    'juncB': 'S47D',
    'juncA': 'S47D_S',
    'juncB': 'S47B_C',
    'juncDistance': 17535.28122721}}]}‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
DarrenWiens2
import copy
new_list = []
mydict
    'juncA': 'S47D',
    'juncB': 'CR-03.0',
    'juncA': 'S47B_C',
    'juncB': 'S47D_S',
    'juncA': 'CR-03.0',
    'juncB': 'S47D',
    'juncA': 'S47D_S',
    'juncB': 'S47B_C',
