Shape file widget issue while uploading File
542
02-13-2019 05:24 AM
tarunvisvanadula1
Hi robert,
i have created custom shape file widget,it is working Fine in my system when i share the widget to other, im facing below issue.
cannot read property name of undefined.
I have attached my code below.please go through it
RobertScheitlin__GISP
Tarun,
Does that other machine have a proxy setup like your code is looking for:
esriConfig.defaults.io.proxyUrl = "/proxy/";
tarunvisvanadula1
hi, robert
yes we have provided proxy settings in other machines still no use,is the widget working for you,if working please let me know
Tarun,
  No it does not work for me. You have issue in your code. First error I encounter is that you are using jQuery in your code line 69 but you do not load jQuery dependancies.
