How to use intersect tool
1572
02-11-2019 08:37 AM
IrfaanYasin
Hi Guys,
I'm drawn a buffer of 30m around pipework.  I have also drawn a 100m grid.  Now what I want to do is find out which pipes buffer sits in each grid square, and how much area within the grid it covers.
Any ideas how to do this?
DanPatterson_Retired
If you have useful projected data, or can calculate area in each layer in projected coordinates,
then the information should be in the table.
There are a couple of options that you can look at
Intersect—Help | ArcGIS Desktop  (use ratio policy)
How Pairwise Intersect works—Help | ArcGIS Desktop
but I like
Union—Help | ArcGIS Desktop  (use ratio policy)
since I like to track what didn't intersect
but I like
ChrisDonohue__GISP
Another option:
Identity—Help | ArcGIS Desktop
Though Union and Intersect are probably easier to get started with.
Chris Donohue, GISP
IrfaanYasin
Thanks guys.  Just to point out the tools were working, but the reason I kept getting failures was because I was exporting to a shape file, and it had more lines than excel could handle, so the data was getting lost.  Exported to a GeoDatabase, and it all worked fine.
