Converting "scene" information into a 2-D "Map" and a share web layer
879
02-11-2019 12:55 PM
BradfordDean
hi folks, I have a technical question.
I created a scene in ArcGIS Pro and am using the "analysis" tab and then the "Interaction angle" tab.
( underneath is the title: "3D exploratory analysis" ribbon).
So I have made this fantastic 2 colour map showing what can be seen (blue) and not seen (red) from a hypothetical wifi tower over the territory I'm studying.
My question is, how can I transfer that "scene" tab into my "map" tab?
Thank you
BradfordDean
ok, 1 day later I found an answer after exploring further .
After you create your scene 2-colour map using the interactive tool. , in the "exploratory analysis" window to the right where it shows the details of your viewshed, there is a hambuger icon. Click the hamburger icon and one of the options available to you is "convert to features". You will then be given the opportunity to call it a name. And in your contents pane it will be created with the name you gave it.
It has to be a 2-d layer, not a 3-d layer. (I'm not sure how I did that, converting a 3-d layer to a 2-d layer)
There in the contents pane right mouse click IN THE 2-D LAYER and select "sharing" then "share as web layer"
make sure you add a summary and tag and a unique name, then click "run"
You now have a web layer showing the visibility from a point of view you can add to your online web GIS
