Convert Queried Feature to ArcGIS Feature - ArcGIS Android SDK
1400
02-08-2019 10:29 AM
ShanMGIS
Hello Everyone,
Given below are my scenario
Query the service Url with object id then if it contains any attachment then display it and facilitate the user to add attachments.
I have referred the samples and found the Edit attachment. But in that it has been done through ListenableFuture<IdentifyLayerResult>. But instead I want to do it with ListenableFuture<FeatureQueryResult>
Everything fine till the query and getting result. After getting result and iterating through next. I am getting result as feature and could not find any method to convert  from com.esri.arcgisruntime.data.Feature to com.esri.arcgisruntime.data.ArcGISFeature. Please suggest me on this.
Given below Code Snap
private void QueryFeatureandLoad()
    mServiceFeatureTable = new ServiceFeatureTable(getString(R.string.sample_service_url));
    mServiceFeatureTable.setFeatureRequestMode(ServiceFeatureTable.FeatureRequestMode.ON_INTERACTION_CACHE);
    // create the feature layer using the service feature table
    mFeatureLayer = new FeatureLayer(mServiceFeatureTable);
    // clear any previous selection
    mFeatureLayer.clearSelection();
    mSelectedArcGISFeature = null;
    final QueryParameters query = new QueryParameters();
    final String searchString ="objectid=77";
    //make search case insensitive
    query.setWhereClause(searchString);
    final ListenableFuture<FeatureQueryResult> future = mServiceFeatureTable.queryFeaturesAsync(query, ServiceFeatureTable.QueryFeatureFields.LOAD_ALL);
    // add done loading listener to fire when the selection returns
    future.addDoneListener(new Runnable() {
        @Override
        public void run() {
            try {
                // call get on the future to get the result
                FeatureQueryResult result = future.get();
                // check there are some results
                if (result.iterator().hasNext()) {
                    // get the extend of the first feature in the result to zoom to
                    Feature feature = result.iterator().next();
                    Envelope envelope = feature.getGeometry().getExtent();
                    mMapView.setViewpointGeometryAsync(envelope, 10);
                       //Select the feature
                    mFeatureLayer.selectFeature(feature);
             //*** GOT STUCKUP HERE * mselectedArcGISFeature is ArcGISFeature ---- How to Convert Feature to ArcGISFeature
                    mAttributeID = mSelectedArcGISFeature.getAttributes().get("objectid").toString();
                    // get the number of attachments
                    final ListenableFuture<List<Attachment>> attachmentResults = mSelectedArcGISFeature.fetchAttachmentsAsync();
                    attachmentResults.addDoneListener(new Runnable() {
                        @Override
                        public void run() {
                            try {
                                attachments = attachmentResults.get();
                                Log.d("number of attachments :", attachments.size() + "");
                                // show callout with the value for the attribute "typdamage" of the selected feature
                                mSelectedArcGISFeatureAttributeValue = (String) mSelectedArcGISFeature.getAttributes().get("typdamage");
                                if (progressDialog.isShowing()) {
                                    progressDialog.dismiss();
                                showCallout(mSelectedArcGISFeatureAttributeValue, attachments.size(),mapPoint);
                                Toast.makeText(MainActivity.this, getApplication().getString(R.string.info_button_message), Toast.LENGTH_SHORT).show();
                            } catch (Exception e) {
                                Log.e(TAG, e.getMessage());
                } else {
                    Toast.makeText(MainActivity.this, "No states found with name: " + searchString, Toast.LENGTH_SHORT).show();
                Toast.makeText(MainActivity.this, "Feature search failed for: " + searchString + ". Error=" + e.getMessage(),
                Log.e(getResources().getString(R.string.app_name),
                        "Feature search failed for: " + searchString + ". Error=" + e.getMessage());
ShanMGIS
I have implemented given below code  and the issue got resolved now
mSelectedArcGISFeature = (ArcGISFeature)result.iterator().next();
