Open Data Portal Statistics
1682
02-01-2019 02:04 PM
AlexanderVencill1
Is there a built in way to look at statistics for our open data portal such as views and downloads? If not what is the easiest way to do this?
by Anonymous User
Not applicable
For the most details - set up a google analytics key and configure it on your site. You can read more on setting up a GA key here - Get started with Analytics - Analytics Help
You may want to consult your organization as many already use Google analytics. Once you have the key, simply add it to your site under the "Configuration" section.
For a more general look at what's going on, check out your Site's Dashboard tab. This will show you an overview of views and unique views.
by Anonymous User
Not applicable
NathanEnge
Hi Graham. does Hub have an exposed API that a thirdparty analytics software could hit, if the the client cannot use GA? I can't seem to find documentation on this.
by Anonymous User
Not applicable
Not at this time but it's something we are working on.
